[Fwd: Re: [Gdal-dev] ogrinfo output lists no features on a postgis
layer created as a copy using "create table as"]
Frank Warmerdam
warmerdam at pobox.com
Sun Dec 17 13:56:11 EST 2006
Dolf Andringa wrote:
> Well, I've found out what the problem was thanks to Frank and Juergen
> Fischer (via irc)...
> The problem was that the schema name contains a -. In postgres that is
> not a problem when you put the schema name in double quotes. ogrinfo
> places only the tablename in double quotes, not the schema name. That is
> what is going wrong......
> Should I commit this as a bug report?
> Thanks for your help Frank!
Dolf,
Yes, please do submit it as a bug report. Ideally with the specific SQL
to create such a schema and a table in it with one feature.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
