[Gdal-dev] trouble on compiling and using ogr with Oracle Spatial
abhay menon
abhay.menon at gmail.com
Tue Dec 19 11:33:15 EST 2006
On 12/19/06, Francesco Sozzi <fsozzi at intercad.ch> wrote:
> Hi All,
> I'm trying to compile ogr with Oracle Spatial.
> I changed nmake.opt with the following:
> # Add ORACLE support.
> ORACLE_HOME = D:\oracle\ora92
> !IFDEF ORACLE_HOME
> OCI_LIB = $(ORACLE_HOME)\oci\lib\msvc\ociw32.lib \
> $(ORACLE_HOME)\oci\lib\msvc\oci.lib
> !ENDIF
> ORACLE_HOME path is correct.
> Then I compiled and I got binaries (such as ogr2ogr.exe).
> But if I try to issue a test as
> ogr2ogr -f OCI OCI:scott/tiger at franz C:\App\TI-CantoneSHP\comuni.shp
> I get the error "Unable to find driver 'OCI'"
> Any suggestions?...
> Best regards
> Francesco
Hello Francesco,
which version of gdal are you compiling.
if you using gdal-1.3.2 or later
comment out : #OCI_PLUGIN = YES
this probably should solve the problem.
Best Regards
Abhay Menon
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061219/b6a23a0e/attachment.html
