[Gdal-dev] Virtual Spatial connection to PostgreSQL ODBC driver
Jeff McKenna
jmckenna at dmsolutions.ca
Tue Dec 19 17:31:35 EST 2006
I had reported this problem to this list a few weeks ago, and left it,
but now I must solve if for a project. Does anyone have any ideas?
thanks.
jeff
Jeff McKenna wrote:
> and all information_schema tables have proper column definitions, for
> example:
> Table "information_schema.sql_sizing_profiles"
> Column | Type | Modifiers
> sizing_id | cardinal_number |
> sizing_name | character_data |
> profile_id | character_data |
> required_value | cardinal_number |
> comments | character_data |
> jeff
> Jeff McKenna wrote:
>> I'm attempting to connect to X/Y data stored in a PostgreSQL table (no
>> geometry) through OGR:ODBC, and getting the following errors:
>> ogrinfo ODBC:@mydsn xxx -summary
>> ERROR 1: No column definitions found for table 'sql_features', layer
>> not usable.
>> 'sql_implementation_info', layer
>> not usable.
>> ERROR 1: No column definitions found for table 'sql_languages', layer
>> not usable
>> ERROR 1: No column definitions found for table 'sql_packages', layer
>> not usable.
>> ERROR 1: No column definitions found for table 'sql_sizing', layer not
>> usable.
>> ERROR 1: No column definitions found for table 'sql_sizing_profiles',
>> layer not
>> usable.
>> INFO: Open of `ODBC:@mydsn'
>> using driver `ODBC' successful.
>> Layer name: xxx
>> Geometry: Unknown (any)
>> Feature Count: 840
>> Layer SRS WKT:
>> (unknown)
>> nf: Integer (10.0)
>> pe: Integer (10.0)
>> ns: Integer (10.0)
>> nb: Integer (10.0)
>> qc: Integer (10.0)
>> on_: Integer (10.0)
>> So for some reason the ODBC:OGR connection cannot find the
>> information_schema tables, even though they exist, shown here in psql:
>> List of relations
>> Schema | Name | Type | Owner
>> information_schema | sql_features | table | postgres
>> information_schema | sql_implementation_info | table | postgres
>> information_schema | sql_languages | table | postgres
>> information_schema | sql_packages | table | postgres
>> information_schema | sql_sizing | table | postgres
>> information_schema | sql_sizing_profiles | table | postgres
>> public | xxx | table | postgres
>> This becomes a show-stopper when trying to display the layer in
>> MapServer:
>> msDrawMap(): Image handling error. Failed to draw layer named 'xxx'.
>> <br>
>> msOGRFileNextShape(): OGR error. No column definitions found for table
>> 'sql_sizi
>> ng_profiles', layer not usable. <br>
>> These same errors occur with GDAL 1.3.2 and CVS-head. I'm connecting
>> as the postgres user, which owns the information_schema tables and my
>> x/y table.
>> Anyone see what I am doing wrong?
>> thanks.
>> jeff
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
