[Gdal-dev] accessing MODIS L1B geolocation data with gdal
Frank Warmerdam
warmerdam at pobox.com
Wed Dec 20 07:06:56 EST 2006
Huw Lynch wrote:
> Sorry if this question has been asked before; I've searched but can't
> find a full explaination.
> I am trying to access geolocation information in MODIS L1B data files. I
> was hoping that the Latitude and Longitude data sets would be visible
> via gdalinfo however when I run this those 2 datasets appear to be
> skipped over.
> Here's a gdalinfo output from an example modis data file;
Huw,
Try a gdalinfo on one of the subdatasets. If things are setup properly,
and you have a very recent build of GDAL you should see something about
geolocation data with subdataset pointers to the lat and long arrays.
You might need to add "-mdd geolocation" to the gdalinfo commandline, and
might need to use the most recent FWTools release if you are working with
GDAL 1.3.2.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
