[Gdal-dev] What driver name to use for writing to HDF4
Thu Feb 2 08:51:48 EST 2006
On 2/1/06, Peng Gao <pgao at esri.com> wrote:
> What's format driver, HDF4 or HDF4Image, should I use? Can I use
> a regular output file name for HDF4Image instead of the coded subdataset
> name,
> if I need to use HDF4Image driver?
Gao,
You would need to use the HDF4Image driver when
creating HDF4 data.  The HDF4 driver has no create
or create copy method.
Best regards,
