[Gdal-dev] Java SWIG bindings
Collins, Benjamin
collinsb at mitre.org
Thu Feb 2 16:38:52 EST 2006
To All,
I have added support for Java in the SWIG bindings section of the code.
As this is a first commit of some code, I would appreciate anyone who
could test it out!
Some notes:
The build process works on the MS box and the Linux box that I have
access to, but these two machines represent a very small portion of
possible platforms, so I anticipate some time to get the kinks worked
out of the build process.
I have used the most Java-natural classes where I could. That means
exchanging Hashtable, Vector, and Color objects among other things. If
you notice any incompatibilities with the intent of GDAL and my
choices, they can be changed.
I have used NIO Direct ByteBuffers for the main part of the data
exchange in the RasterIO. Please note that I think this is by far the
fastest way to exchange data, but I'm open to other's suggestions. If
you're using something older than Java 1.4 these will not work!
I have one test application in the apps directory, and I have another
to add soon that demonstrates the reading of raster data.
Ben Collins
