[Gdal-dev] export an image to ascii text file
Matthew Perry
perrygeo at gmail.com
Fri Feb 3 16:47:37 EST 2006
Xiaodong,
There is a python script distributed with recent versions of gdal
called "gdal2xyz.py" . I haven't used it for multi-band images and it
appears that the script handles a single band at a time. You could use
this to create a seperate text file for each band or modify it to
output all bands to a single file.
matt
On 2/3/06, Xiaodong Zhang <zhang at aero.und.edu> wrote:
> Hi,
> I need to export an image (any projection) into an ascii file: coma
> delimited columns of lat, lon, band 1, band 2, ..... Before I get on
> that with GDAL library, does anyone have developed or know of such a
> program, which can be shared.
> Thanks
> Xiaodong
> ____________________________________________
> Xiaodong Zhang
> Department of Earth System Science & Policy
> Clifford Hall, Box 9011
> University of North Dakota
> Grand Forks, ND 58202-9011
> Tel. (701)777-6087 | Fax. (701)777-2940
> E-mail: zhang at aero.und.edu
> _____________________________________________
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Matt Perry
http://www.perrygeo.net
