[Gdal-dev] Simple SHP file creation with Python..API question
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 7 09:09:54 EST 2006
On 2/7/06, Aykut KOÇAK <aykutkocak at superonline.com> wrote:
> geo.SetPoint(0,float(loc[0]),float(loc[1]),0)
> map.Release()
> return
> main()
Aykut,
After updating the point geometry in your in-memory
feature, you need to push it back to the datastore to
save it. Try adding something like:
lyr.SetFeature( ftr )
after the SetPoint() call.
In place update of geometries in a shapefile is
relatively new and I only recently added test scripts
checking the capability. Make sure you are using
at least GDAL/OGR 1.3.1.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
