[Gdal-dev] Visual Studio
Tue Feb 7 11:20:05 EST 2006
On 2/7/06, salah jubeh <s_jubeh at yahoo.com> wrote:
> Thank you frank for replaying
>  I downloaded  visual  studio solution form the net. and i was able to compile GDAL with it my  problem is compiling gdaltranslate and gdalinfo , i want to change some  code in gdal translate because the resulting ascii file missing a tag  which is nodatavalue
>   i think this is a bug in the tool itself,
Salah,
Ah, OK.  If you have build problems with the solution
file then I'm off the hook!   I only (attempt) to support use
of the the nmake base makefiles.
If you provide details on the nodata problem, this may be
something I could fix.
Best regards,
