[Gdal-dev] OGR Geometry Contains() function
Mateusz Łoskot mateusz at loskot.net
Wed Feb 8 10:36:06 EST 2006
Aykut KOÇAK wrote:
> Hi there,
> In OGR object tree, is there any chance to adjust some kind of treshold
> for Contains() and similar compare functions? I have some data collected
> with GPS which has got 20 - 40 meters difference from my LINESTRINGs and
> I'd like to match these 2 datasets with a accuracy of eg.30 meters.
> P.S. : using python
Take a look at OGRGeometry::Buffer or geos::Geometry::buffer
http://www.gdal.org/ogr/classOGRGeometry.html#ce5cb0b6728fa36d7e8e8a679244640c
http://geos.refractions.net/ro/doxygen_docs/html/classgeos_1_1Geometry.html#a40
They will return buffer as object of type of geometry and then you can
perform spatial relations checks.
I'm not sure they are exposed for Python.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
