[Gdal-dev] python, multipolygon creation
Frank Warmerdam
warmerdam at pobox.com
Wed Feb 8 21:20:58 EST 2006
On 2/8/06, Didrik Pinte <dpinte at itae.be> wrote:
> Hi,
> I'm trying to write a function for simplifying polygons.
> My input file is a shapefile containing 11 MULTIPOLYGON composed of only
> 1 LINEARRING.
> I can read and simplify the LINEARRINGS but I cannot create add them to
> a new MULTIPOLYGON. The AddGeometryDirectly() method seems to be doing
> nothing.
> Here is the problematic code :
> if geom.GetGeometryCount() > 0:
> print 'Multiple geometries : simplifying %s geometries' %
> new_geom = []
> # for each LinearRing, simplify it and store it in a list
> for i in xrange(geom.GetGeometryCount()):
> in_geom = geom.GetGeometryRef(i)
> new_geom.append( SimplifyGeometry( in_geom, tolerance ) )
> # Creating the output new MultiPolygon
> seg = ogr.Geometry( type= ogr.wkbMultiPolygon )
> # Adding the circles into the polygon
> for ng in new_geom:
> print "Ng points %i" % ng.GetPointCount()
> seg.AddGeometryDirectly(ng)
> seg.CloseRings()
> print "New multipolygon has %i geometries" %
> seg.GetGeometryCount()
> return seg
> Here is the output i always have :
> Multiple geometries : simplifying 1 geometries
> Ng points 1841
> New multipolygon has 0 geometries
> At the end of the process my seg object does not contain any
> geometry ... Is it a problem with the AddGeometryDirectly ?
> I think i've missed something.
> Does anybody have an idea about my problem ?
Didrik,
I believe the problem is that you are attempting
add linearring's directly to a multipolygon. A multipolygon
is supposed to hold only polygons. And polygons have
linear rings. The most direct fix was be to modify
SimplifyGeometry() to return a polygon instead of
a linearring.
The AddGeometryDirectly() method tests certain assumptions,
like the that multipolygons are only allowed to hold polygons, and
takes no action if the assumption fails. I imagine it is returning
an error code. It would perhaps be better if it issue an error
message or possibly threw an exception.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
