[Gdal-dev] release date
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 9 08:02:58 EST 2006
On 2/9/06, Ari Jolma <ari.jolma at tkk.fi> wrote:
> Is there any possibility to get measures support into the next release?
Ari,
I'm afraid there is no chance of getting measures in OGR
geometries introduced for 1.3.2. It's a big job and I'm basically
waiting for the Simple Features revision working group at OGC
(on which I sit) to settle things out before I start implementing
this as part of a general "simple features" overhaul in OGR. Given
that this is likely to result in various breakage, I may also take this
opportunity to do my long planned "unification" of OGR into GDAL.
> It's been rather quiet on the swig side (at least from my point of
> view). I'm using the Perl bindings regularly without problems. Is there
> anything that should be done for the bindings for this release? I should
> at least work a bit on the docs.
I would like to have a proper page on the web site dedicated to each
of the alternate interfaces to GDAL (python, perl, ruby, Java, VB6,
etc) that work fairly well. I don't know if all of them will get done
by 1.3.2, but if you can prepare a "one web page intro" to perl for
GDAL we can cover that off.
The various "gdalscripts" don't really get proper visibility on
the web page currently.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
