[Gdal-dev] ogr_miattrind.cpp dependency
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 9 11:43:09 EST 2006
On 2/7/06, Mateusz Łoskot <mateusz at loskot.net> wrote:
> > I think the best solution to this would be to add some sort
> > of build/preprocessor magic so that if the mapinfo driver isn't
> > included in a build, the attribute indexing will also be dropped.
> > This may be a bit messy.
> Do you think it's something recommended or expected by other users?
> Or there is no problem with current state of this configuration?
Mateusz,
This is an issue for very few users (developers). I'm not keen
on doing anything about this, but if there is enough interest
(or better yet helpers) something could be done.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
