[Gdal-dev] MrSID driver with 16bit output
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 14 23:36:25 EST 2006
Chapman, Martin wrote:
> I have a 16bit (GDT_UInt16) tiff file that I am trying to copy to a
> UInt16 jp2 file using the MrSID esdk 6.x driver. When I try to remap it
> to 8-bit uchar it works fine. When I try to just copy it to jp2 it
> fails. It looks like the only diff between the two operations is the
> datatype used to initialize the JP2WriterManager object in the
> JP2CreateCopy() method of the mrsiddataset.cpp file. In
> MrSIDDummyImageReader::initialize() the datatype is set to
> LTI_DATATYPE_UINT16 instead of LTI_DATATYPE_UINT8. Can anyone confirm
> this to be a problem in the GDAL mrsid driver?
Martin,
I have confirmed the same behavior. If you file a bug on this against
GDAL I'll try and dig into it tomorrow (Wednesday).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
