[Gdal-dev] Ogr2ogr crashes for MiF/Mid
Daniel Morissette dmorissette at dmsolutions.ca
Wed Feb 15 08:18:15 EST 2006
Marc Jacquin wrote:
> Hi all,
> Ogr2ogr seems to be a convenient tool for transforming WKT geometries into
> other formats like Shape files or MapInfo files.
> But ogr2ogr crashes when using MapInfo File output, runs OK for the same
> command line with ESRI Shapefile output.
> ogr2ogr -f "MapInfo File" d:/temp/aaaa.mif PG:"user=xxx dbname=postgres
> host=localhost port=5432 password=zzzz" -sql "select
> Geomfromtext('POLYGON((-15 -15, -15 15, 15 15,15 -15,-15 -15))')"
> It runs OK too with the name of a table instead of the SQL statement.
Marc,
Can you please try converting from the postgres DB to shapefile, and
then from shapefile to mif/mid. If that still produces the crash then
please submit a bug, attach the shapefile dataset that can be used to
reproduce the problem, and assign it to me. Also please indicate which
version of OGR you're using.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
