[Gdal-dev] creating a composite raster
Thu Feb 16 19:57:06 EST 2006
Christopher Condit wrote:
> I’m looking for a way to take three equally sized input raster files in
> AAI/Grid format and convert each grid to a band in a single 24-bit
> raster file (r, g, b, respectively).
> Is there an easy way to accomplish this with GDAL?
Chris,
If you have a GDAL build that includes the python support, you can
do "gdal_merge.py -o stack.tif -separate a.grd b.grd c.grd".
This would stack each of the .grd files into a separate band of the
output file, stack.tif.
Best regards,
