[Gdal-dev] Mysql support
Howard Butler
hobu at iastate.edu
Fri Feb 17 14:18:19 EST 2006
Joe,
If you can do a cvs update, there were quite a few changes to the
mysql driver yesterday and the day before. These may have an impact
on your issues.
Also, you can just let ogr2ogr *create* the spatial_ref_sys and
geometry_columns table for you in a fresh database without manually
doing it yourself. Were you just letting ogr2ogr do it, or were you
doing with some sort of sql command?
Howard
At 12:14 PM 2/17/2006, Miller Joseph wrote:
>Content-class: urn:content-classes:message
>Content-Type: multipart/alternative;
> boundary="----_=_NextPart_001_01C633ED.EB75D952"
>Hey all,
>With some tweaking of ogrmysqllayer.cpp and pcrtypes.h I was able to
>get the daily build of feb 13 to compile and link on a windows xp
>system using visual c 6.0.
>I used to ogr2ogr to create the Geometry_Columns table and I created
>a spatial_ref_sys table as described in:
><http://home.gdal.org/projects/osvecdb/sfsql-schema.html>http://home.gdal.org/projects/osvecdb/sfsql-schema.html
>I altered the geometry_columns so that the srid column was a foreign
>key from the spatial ref table.
>I am still not having luck having ogrinfo reflect the srid
>information I entered. I even made sure that data I entered using
>the Geomfromtext function included the srid. My question is whether
>I am doing something wrong or if I should wait for a later build to
>be released before the spatial_ref_sys table is supported??
>Thanks in advance,
>Joe Miller
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
