[Gdal-dev] Set Projection
salah jubeh
s_jubeh at yahoo.com
Mon Feb 20 16:42:21 EST 2006
Hello.
I am creating an image out of another image, i read the meta data information from one image and assign it to he other image.
this is the code i use to do it.
DALSetGeoTransform( hDstDS, adfGeoTransform );
GDALSetProjection( hDstDS, pszPrettyWkt);
hBand = GDALGetRasterBand( hDstDS, 1 );
GDALRasterIO( hBand, GF_Write, 0, 0, nXSize, nYSize,
pafScanline, nXSize, nYSize, GDT_Float32, 0, 0 );
GDALClose( hDstDS );
When i comment the GDALSetProjection( hDstDS, pszWkt); i find that the image geotransformation matrix was set correctly . Also when i use GDALSetProjection( hDstDS, pszWkt); the geo transformation matrix not inserted neither the projection.
I checked the PszWkt it give me this
PROJCS["IMAGINE GeoTIFF Support
Copyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: egtf.c $ $Revision: 1.10.1.6 $ $Date: 2003/10/17 16:36:51EDT $
Projection Name = Transverse Mercator
Uni",GEOGCS["IMAGINE GeoTIFF Support
Unable to match Ellipsoid (Datum) to a Ge",DATUM["unknown",SPHEROID["unnamed",63
78137,298.2572220960423]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433
]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER
["central_meridian",24],PARAMETER["scale_factor",0.9996],PARAMETER["false_eastin
g",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]
The original image has this prjection
Projection: Transverse Mercartor
Spheroid:GRS 180
Datum:EGSA 97
I notice here the datum and the spheroid are not recognized is this why i can not update the projection.
Relax. Yahoo! Mail virus scanning helps detect nasty viruses!
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060220/10a0ca1f/attachment.html
