[Gdal-dev] Raster to Polygon
Lennox Antoine lxnyce at gmail.com
Wed Feb 22 16:39:23 EST 2006
I posted simple raster to vector conversion capability in my GDAL
application located here :
http://www.lennoxgis.com/
Download the 0.9 stable client, and load your rasters. In the
treeview, highlight all the rasters you want to convert, and right
click on them (after they load that is). Select vectorize, and pick
your output directory. It will vectorize them into 2D line shapefiles.
You can batch your vectorizations this way.
The software is still pretty much unreleased, but hopefully it will
solve this need.
-Lennox
On 2/22/06, Christopher Condit <condit at sdsc.edu> wrote:
> At one time a few years ago there was talk of adding simple raster to
> polygon functionality to GDAL (see
> http://lists.maptools.org/pipermail/gdal-dev/2003-August/001037.html
> ).  Has that ever materialized?  Does anyone know of an alternate way to
> accomplish this?  I've tried using gdal_countour, but as I expected I just
> get polylines as output.  My raster images are very simple – mostly no data
> values with a few regions that I need to extract to polygons.  In fact, I
> can even re-class to 0s and 1s if necessary.
> Thanks!
> Chris
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
