[Gdal-dev] problem compiling with VS.NET
Mateusz Łoskot
mateusz at loskot.net
Fri Feb 24 18:09:09 EST 2006
Thom DeCarlo wrote:
> Hi,
> I just downloaded last night's tarball. Attempting to compile on WinXP with
> VS.NET 2003 very quickly yielded this:
> cl /nologo /MD /EHsc /Ox -I..\port -I..\ogr -I..\gcore -I..\alg /c
> cpl_vsi_mem.cpp
> cpl_vsi_mem.cpp
> cpl_vsi_mem.cpp(614) : error C3861: 'string': identifier not found, even
> with argument-dependent lookup
> NMAKE : fatal error U1077: 'cl' : return code '0x2'
> Stop.
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio .NET
> 2003\VC7\BIN\nmake.exe"' : return code '0x2'
> Stop.
> Any idea why this is happening?
Hi Thom,
You're right. There was small bug, likely caused by my changes I made
for Windows CE port.
I've just applied patch to the CVS repository.
Do clean checkout from CVS and it should work.
I've just tried to build GDAL with VC++ 7.1 and it compiles well.
If you don't want to do clean checkout, here is the patch.
Just replace the line marked with (-) with line marked with (+).
In case of any problem give me a note.
Index: port/cpl_vsi_mem.cpp
RCS file: /cvs/maptools/cvsroot/gdal/port/cpl_vsi_mem.cpp,v
retrieving revision 1.9
diff -u -a -r1.9 cpl_vsi_mem.cpp
--- port/cpl_vsi_mem.cpp 19 Feb 2006 21:54:34 -0000 1.9
+++ port/cpl_vsi_mem.cpp 24 Feb 2006 23:03:09 -0000
@@ -609,9 +609,8 @@
void VSIInstallMemFileHandler()
- VSIFileManager::InstallHandler( string("/vsimem/"),
+ VSIFileManager::InstallHandler( std::string("/vsimem/"),
new VSIMemFilesystemHandler );
Mateusz Łoskot
http://mateusz.loskot.net
