[Gdal-dev] DWG/DXF *Writing* Driver for OGR
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 3 16:13:47 EST 2006
Folks,
With the support of OSGIS and the Dutch Directorate for Public
Works and Water Management, Rijkswaterstaat, Adviesdienst
Geo-informatie en ICT (RWS AGI), I have implemented an
OGR driver for writing DXF and DWG files.
The driver is documented at:
http://www.gdal.org/ogr/drv_dxfdwg.html
It depends on the Open Design Alliance DWGdirect library,
which is not properly open source. I would also stress
that the driver is currently write-only. There is currently no
support for reading DXF or DWG files in OGR.
Those interested in testing the driver should build GDAL/OGR
from a nightly CVS snapshot, and will need to acquire the
DWGdirect libraries from the Open Design Alliance themselves.
I am interested in feedback.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
