[Gdal-dev] ogr2ogr Point not Point ZM
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 5 14:27:59 EST 2006
On 1/5/06, Alex Mandel <tech_dev at wildintellect.com> wrote:
> When I do:
> ogr2ogr -update -append two.shp one -nln two one -nlt POINT
> The appended file, which has no points to begin with(but is basically
> the same as the original with a couple of extra fields and the points
> removed) ends up with geometry of type POINT ZM(3D). I need it to simply
> be POINT(2D), no z or m values. ArcGIS software handles POINT and POINT
> ZM very differently so they are two distinctly different options.
> I thought I had solved it by adding the -nlt POINT portion but it turns
> out that didn't have any effect.
Alex,
If two.shp already exists, then whether it is POINT or POINTZM is
already established. How are you creating it?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
