[Gdal-dev] Problems installing GDAL 1.3.1 on Red hat enterprise
linux advanced server 3.0.
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 6 16:46:10 EST 2006
On 1/6/06, William Hudspeth <bhudspeth at edac.unm.edu> wrote:
> Hello, I am trying to install GDAL 1.3.1 on Red hat enterprise linux
> I have configured successfully with the following:
> ./configure --prefix=/usr/local/gdal --without-grass --with-python --
> with-hdf4=/usr/local/hdf4/lib
Bill,
Are the following really the first errors reported? It seems
like some of the include files may not be found, but then there
should be other errors reported. The "--with-hdf4=/usr/local/hdf4/lib"
also seems a bit odd. Shouldn't you be pointing it at the base
directory? The level about the lib directory?
> But then get errors on make:
> EHapi.c:3524: syntax error before "EHclose"
> EHapi.c:3524: syntax error before "fid"
> EHapi.c:3525: warning: return type defaults to `int'
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
