[Gdal-dev] ecw
ivan marchesini marchesini at unipg.it
Fri Jan 6 05:14:44 EST 2006
Hi list...
I have tried to compile the gdal.1.3.1  against the ecwsdk.3.1
downloaded from http://www.gdal.org/dl/
I have a system with debian testing-unstable (a mix)
I have already installed GrassGis against gdal (without ecw)
and now I try to compile the gdal libraries with ecw support
these are the steps:
__________________________________________________
  ./configure --with-grass=/usr/local/grass-6.1.cvs/
--with-ecw=/home/ivan/Documents/GRASS/GDAL/ecwsdk-3.1.25Jan05-linux
GDAL is now configured for i686-pc-linux-gnu
  Installation directory:    /usr/local
  C compiler:                gcc -O2
  C++ compiler:              g++ -O2
  LIBTOOL support:           yes
  LIBZ support:              external
  GRASS support:             grass57+
  CFITSIO support:           no
  PCRaster support:          internal
  NETCDF support:            no
  LIBPNG support:            external
  LIBTIFF support:           external
  LIBGEOTIFF support:        internal
  LIBJPEG support:           external
  LIBGIF support:            internal
  OGDI support:              no
  HDF4 support:              yes
  HDF5 support:              no
  KAKADU support:            no
  JASPER support:            yes (GeoJP2=no)
  ECW support:               yes
  MrSID support:             no
  POSTGRESQL support:        yes
  MySQL support:             no
  XERCES support:            no
  ODBC support:              no
  OCI support:               no
  DODS support:              no
  SQLite support:            no
  GEOS support:              yes
  Statically link PROJ.4:    no
  Traditional Python:        no
  NG SWIG Bindings:
  enable OGR building:       yes
It seems all ok!!!!
then "make" but I obtain this error:
___________________________________________________
 make[2]: Entering directory
`/home/ivan/Documents/GRASS/GDAL/gdal-1.3.1/frmts/ec
w'
/bin/sh ../../libtool --mode=compile g++ -Wall  -O2   -I../../port
-I../../gcore
 -I../../alg -I../../ogr -I../../ogr/ogrsf_frmts -DFRMT_ecw -I../../port
-I/home
/ivan/Documents/GRASS/GDAL/ecwsdk-3.1.25Jan05-linux/include  -c
-o ../o/ecwdatas
et.o ecwdataset.cpp
 g++ -Wall -O2 -I../../port -I../../gcore -I../../alg -I../../ogr
-I../../ogr/og
-I/home/ivan/Documents/GRASS/GDAL/ecwsdk-3.1.2
5Jan05-linux/include -c ecwdataset.cpp  -fPIC -DPIC
-o ../o/.libs/ecwdataset.o
/home/ivan/Documents/GRASS/GDAL/ecwsdk-3.1.25Jan05-linux/include/NCSJP2FileView.
h:820: error: ISO C++ forbids declaration of 'CNCSJPCResample' with no
type
h:820: error: expected ';' before '*' token
/home/ivan/Documents/GRASS/GDAL/ecwsdk-3.1.25Jan05-linux/include/NCSJPCPacket.h:
32: warning: 'class CNCSJPCPacket' has virtual functions but non-virtual
destruc
tor
make[2]: *** [../o/ecwdataset.o] Error 1
make[2]: Leaving directory
`/home/ivan/Documents/GRASS/GDAL/gdal-1.3.1/frmts/ecw
make[1]: *** [ecw-install-obj] Error 2
make[1]: Leaving directory
`/home/ivan/Documents/GRASS/GDAL/gdal-1.3.1/frmts'
make: *** [frmts-target] Error 2
_____________________________________________________________-
Can someone help me to solve this problem????
thank you very much for your help!!!
ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
