[Gdal-dev] gdal_contour missing contours!
Frank Warmerdam
warmerdam at pobox.com
Sat Jan 7 16:29:34 EST 2006
On 1/7/06, Jeshua Lacock <jeshua at openosx.com> wrote:
> Doh!
> Of course, I was starting to suspect that myself.
> Can you recommend a method of exporting a DEM from GRASS?
Jeshua,
I assume that r.out.gdal to an appropriate format (such as
GeoTIFF) would do the trick if you have that setup properly.
If not, I was just successful with the sequence:
r.out.bin -b input=elevation output=etopo5
gdal_contour -i 200 etopo5 contour
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
