[Gdal-dev] MrSID ESDK problems
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 10 09:03:16 EST 2006
On 1/10/06, Bart van den Eijnden (OSGIS) <bartvde at xs4all.nl> wrote:
> Hi list,
> we are having some problems getting the MrSID ESDK to work with GDAL CVS
> (04-01-2006). We have bought the ESDK from Lizardtech.
Bart,
What version is the ESDK?
> It is listed as output format, but gdal_translate won't write a MrSID
> file, it reports something like output format not supported.
Does "gdalinfo --format mrsid" have a line reporting
"Supports: CreateCopy()..."?
> Any ideas what this could be? Thanks in advance.
Are you building on windows or linux? Is the -DMRSID_ESDK
compile option in effect when mrsiddataset.cpp is compiled?
My guess is some sort of configuration problem is preventing
from the encoding support getting enabled.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
