[Gdal-dev] PostGIS varchar fields
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Jan 10 19:46:35 EST 2006
I'm not sure if it's supposed to work this way or not:  I extracted
an area out of a big PostGIS database, to shapefile, and all the
varchar fields from PostGIS became character fields of length 80.  So
all those 2-8 varchar fields in the attributes balloon the dbf, and
the few 200 char name fields get chopped off.
ogrinfo -al -so on the PostGIS DB returns "String (0.0)" for the
field type for all varchar fields, but the correct length for all
fixed char fields (a few 1 and 2-char fields).  The original mif/mid
source I used to create the PostGIS DB with ogr2ogr returns the
correct length for all char fields.  A direct ogr2ogr from the mif/
mid to shapefile also creates the correct field lengths in the
shapefile, although the integer fields get changed to reals.
GDAL 1.3.1 with Postgres 8.0.4 libs on client end, Postgres 8.0.4 +
PostGIS 1.0.6 on PG server.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
