[Gdal-dev] OGR MySQL development
Howard Butler
hobu at iastate.edu
Mon Jan 16 11:13:26 EST 2006
List,
I have been making improvements to OGR's MySQL driver. These
improvements including being able to natively read MySQL geometries
and eventually will include write support for MySQL. I have been
testing with MySQL 5.0.18 on both OS X and Fedora Core 3. No
guarantees for anything less than that at this point.
A summary of what has been completed so far:
- Detect geometry columns
- Read geometries from MySQL using AsBinary()
- Read geometry column from geometry_columns table
- Detect geometry type from geometry_columns table
- Read srid and srtext from spatial_ref_sys
If you are interested in playing with this, look at the load2mysq.py
script in pymod/samples. This can be used to load an OGR layer into
MySQL. It will create a spatial index as well as geometry_columns
and spatial_ref_sys tables. I have been testing with Schuyler's
world_borders.shp <http://mappinghacks.com/data/world_borders.zip>,
and you may have to edit the 4326 SRID values in the script if your
data is in something different.
MySQL in CVS should be considered unstable until some point in the
near future once these additions are complete. If you decide to play
around with it, I'd be interested in hearing how it goes and what
troubles you have. As always, I'm on #gdal on IRC.
Howard
