[Gdal-dev] WKB byte order and SWIG
Charlie Savage
cfis at interserv.com
Tue Jan 17 14:34:02 EST 2006
Something that tripped me up today. I see in the SWIG bindings for OGR
that the byte order is assumed to be big endian (from ogr.i):
OGRErr ExportToWkb( int *nLen, char **pBuf, OGRwkbByteOrder
byte_order=wkbXDR ) {
Note that default parameter. This seems to me like a really bad idea,
because it means you can write code on an Intel computer (which is what,
95% of all computers people use?) like this:
wkb1 = geom1.export_to_wkb()
And have no idea that the result you just got back is wrong. I think
that byteOrder should not have a default value - and if it must, it
really should be wkbNDR.
Unless someone says something, I plan on removing the default value and
making this a required parameter, just like it is in the C OGR API.
Charlie
