sheba thomas wrote: > can any one please tell the Shapefile header content or the structure > of the shapefile header. You can read about it in ESRI Shapefile spec: http://shapelib.maptools.org/dl/shapefile.pdf Cheers -- Mateusz Łoskot http://mateusz.loskot.net
