[Gdal-dev] troubles with gdaltindex
Jeff Moxley
jmoxley at grca.on.ca
Fri Jan 20 14:24:31 EST 2006
Thanks for the help on this. I have attempted to use the FWTools
version and I get the error:
It appears no georeferencing is available for "<imagespath>".
I am using jpg with a world file .jgw. Is there a way to specify what
the world file is?
Jeff
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of
Frank Warmerdam
Sent: Friday, January 20, 2006 10:23 AM
To: Jeff Moxley
Cc: gdal-dev at lists.maptools.org; Assefa Yewondwossen
Subject: Re: [Gdal-dev] troubles with gdaltindex
On 1/19/06, Jeff Moxley <jmoxley at grca.on.ca> wrote:
> I am working with MS4W and want to create a WMS for our Ortho Photos.
I am
> attempting to use gdaltindex to create my index file. When I run
gdaltindex
> I get the following message:
> ERROR 4: 'images/*.jpg' does not exist in the file system, and is not
> recognized as a supported dataset name.
Jeff,
It would seem the problems it that the gdaltindex in
MS4W was not built with wildcards enabled. To do
so, it is necessary to build GDAL with the VCDIR
value in nmake.opt properly set, and the SETARGV
line in nmake.opt uncommented.
I am cc:ing Assefa in the hopes he could do this in a
future release.
In the meantime, you might want to download FWTools
and use gdaltindex from that.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
