[Gdal-dev] (little) Problem with the gdal_translate srcwin option
Olivier Wymann
olivier.wymann at itelios.com
Thu Jan 26 05:33:39 EST 2006
I'm using gdal v1.3.1.0, and I got a problem when I try to extract a
subwin from a geotiff file :
gdal_translate -srcwin 400 400 230 360 test.tif dest.tif
The output file size and new geocoordinates seem to be ok, but the
problem is the new file itself : in TatukGIS, the dest.tif file looks as
if the 3 bans where displayed with 3 different vertical offsets (not
very easy to explain...imagine the red band starting at y=0, the green
at y= n and the blue starting at y=approximately n+n), but curiously,
where I open the file in Photoshop, or if I translate it in JPEG, it
looks great. Any Idea ?
FILE INFORMATIONS :
Original
Driver: GTiff/GeoTIFF
Size is 2299, 1686
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (1.356243,43.109269)
Pixel Size = (0.00005390,-0.00005390)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 1.3562432, 43.1092686) ( 1d21'22.48"E, 43d
Lower Left ( 1.3562432, 43.0183852) ( 1d21'22.48"E, 43d
Upper Right ( 1.4801703, 43.1092686) ( 1d28'48.61"E, 43d
Lower Right ( 1.4801703, 43.0183852) ( 1d28'48.61"E, 43d
Center ( 1.4182067, 43.0638269) ( 1d25'5.54"E, 43d
Band 1 Block=2299x1 Type=Byte, ColorInterp=Red
Band 2 Block=2299x1 Type=Byte, ColorInterp=Green
Band 3 Block=2299x1 Type=Byte, ColorInterp=Blue
COMMAND
(performs without warnings)
SUBWIN FILE
>gdalinfo dest.tif
Size is 230, 360
GEOGCS["WGS 84",
DATUM["WGS_1984",
Origin = (1.377805,43.087707)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 1.3778051, 43.0877067) ( 1d22'40.10"E, 43d 5'15.74"N)
Lower Left ( 1.3778051, 43.0683010) ( 1d22'40.10"E, 43d 4'5.88"N)
Upper Right ( 1.3902032, 43.0877067) ( 1d23'24.73"E, 43d 5'15.74"N)
Lower Right ( 1.3902032, 43.0683010) ( 1d23'24.73"E, 43d 4'5.88"N)
Center ( 1.3840042, 43.0780038) ( 1d23'2.41"E, 43d 4'40.81"N)
Band 1 Block=230x35 Type=Byte, ColorInterp=Red
Band 2 Block=230x35 Type=Byte, ColorInterp=Green
Band 3 Block=230x35 Type=Byte, ColorInterp=Blue
Thank you for your help
Olivier
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060126/be467f75/attachment.html
