[Gdal-dev] MIF/MID problem
Todd.Southen at bentley.com
Thu Jan 26 13:52:56 EST 2006
Hello all,
I'm having problems reading a MID file with OGR. It appears that it
doesn't like my data as there are spaces after the commas (even though
the delimiter is properly set as ", " in the MIF header). If I change
the delimiter entry in the MIF to "," from ", " then things work fine.
Does OGR not like multicharacter delimiters?
For what its worth, these same files load just fine in MapInfo.
Thank-you,
Todd.
