[Gdal-dev] MIF/MID problem
Todd.Southen at bentley.com
Thu Jan 26 14:41:06 EST 2006
Done, here's the link: http://bugzilla.maptools.org/show_bug.cgi?id=1266
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of
Frank Warmerdam
Sent: Thursday, January 26, 2006 2:11 PM
To: Todd Southen - Consultant
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] MIF/MID problem
On 1/26/06, Todd.Southen at bentley.com <Todd.Southen at bentley.com> wrote:
> Hello all,
> I'm having problems reading a MID file with OGR. It appears that it
> doesn't like my data as there are spaces after the commas (even though
> the delimiter is properly set as ", " in the MIF header). If I change
> the delimiter entry in the MIF to "," from ", " then things work fine.
> Does OGR not like multicharacter delimiters?
> For what its worth, these same files load just fine in MapInfo.
Todd,
I don't believe multi-character delimeters are supported.
Could you submit a bug against MITAB about this? Please assign it
directly to me, since the issue relates in part to the line parsing.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
