[Gdal-dev] GDAL with ECW SDK 3.3 on Mac OS X
Armin Burger
armin.burger at gmx.net
Thu Jan 26 15:44:47 EST 2006
William,
thanks for the clarifications. I guess one has then to wait until the ER
Mapper developers get the things corrected.
Armin
William Kyngesburye wrote:
> Well, succeeded in building, yes. But I get a crash in GDAL when trying
> to read ECW files. It's apparently a known problem for the ECW
> developers, so I didn't pursue it to see what could be done, and I wait
> for them to fix it.
> Anyways, the GDAL configure check problem is because when you specify
> the ecw path, it looks for the linux-style .so library, not a Mac dylib,
> but it does check for libecwj2.dylib. So, when you link in libecwj2, it
> finds that and sets the lib options accordingly, -lecwj2, instead of
> -lNCSEcw -lNCSCnet -lNCSUtil as it needs to be. My fix is to edit the
> GDAL configure and change libNCSCnet.so to libNCSCnet.dylib, instead of
> linking libecwj2.
> There is another problem that will probably crop up next - the ECW
> libraries need the Carbon framework, but the version of libtool used by
> GDAL doesn't pass framework options thru, so you will get some more
> undefined symbols errors. In configure, find where it sets
> CARBON_FRAMEWORK, and change it to:
> CARBON_FRAMEWORK="-XCClinker framework -XCClinker Carbon"
> On Jan 26, 2006, at 12:55 PM, Armin Burger wrote:
>> Hello
>> I guess that some folks succeeded in compiling GDAL with ECW support
>> under Max OS X (Tiger). I tried the combination GDAL 1.3.1 and ECW
>> SDK 3.3 RC1. After applying the once on this list mentioned small
>> patch for the SDK it compiled fine.
>> Then GDAL gives an error during the configure script:
>> checking for libNCSEcw.so or libecwj2... configure: error: not found
>> in /usr/local/lib or /usr/local/bin.
>> The libraries of ECW are under /usr/local/lib. I checked the configure
>> script and just tried a link
>> /usr/local/libecwj2.dylib -> /usr/local/lib/libNCSEcw.0.0.0.dylib
>> The configure then went on. Also the compilation went quite far. But
>> somewhere towards the end of the make I get the error
>> ld: Undefined symbols:
>> __ZN10CNCSThread10GetCurrentEv
>> __ZN10CNCSThread11EnableStatsEv
>> __ZN10CNCSThread11GetPriorityEv
>> __ZN10CNCSThread11IsSuspendedEv
>> __ZN10CNCSThread11SetPriorityE17NCSThreadPriority
>> __ZN10CNCSThread11ThreadYieldEv
>> __ZN10CNCSThread12DisableStatsEv
>> __ZN10CNCSThread3RunEv
>> __ZN10CNCSThread4ExitEi
>> __ZN10CNCSThread4StopEb
>> __ZN10CNCSThread5GetIDEv
>> __ZN10CNCSThread5SpawnEPvb
>> __ZN10CNCSThread6ResumeEv
>> __ZN10CNCSThread7SuspendEv
>> __ZN10CNCSThread8GetStatsEv
>> __ZN10CNCSThread8GetSysIDEv
>> __ZN10CNCSThread9IsRunningEv
>> __ZN10CNCSThread9TerminateEv
>> __ZN9CNCSError15GetErrorMessageEPcz
>> __ZN9CNCSErrorC1E8NCSErrorPciN7CNCSLog11NCSLogLevelEPKc
>> __ZN9CNCSErrorC1ERKS_
>> __ZN9CNCSErrorD1Ev
>> __ZN9CNCSErroraSERKS_
>> _NCSGetErrorText
>> /usr/bin/libtool: internal link edit command failed
>> make[1]: *** [libgdal.la] Error 1
>> make: *** [check-lib] Error 2
>> Does anybody have a clue what this could mean?
>> I set the LD_LIBRARY_PATH and LD_INCLUDE_PATH to all directories where
>> I think it was needed.
>> Thanks for any help,
>> Armin
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what does
> that remind me of? Ah, yes - life."
> - Marvin
