[Gdal-dev] Re: ogr2ogr convert PostGIS-data to MapInfo TAB/ MIF-Files
Fri Jan 27 09:31:41 EST 2006
On 1/27/06, Fischer, Andreas <andreas.fischer at kreis-unna.de> wrote:
> Hello,
> a couple of weeks ago we had an issue about problems converting PostGis-data
> to MapInfo TAB or MIF-files using ogr2ogr.
> You will find the description of the problem under
> http://bugzilla.maptools.org/show_bug.cgi?id=1198.
> Can anyone let me know, if this problem is considered to be fixed?
> I Would be glad to hear from you.
Andreas,
With your prompting I have dug into this and fixed it in CVS.
Let me know if you have further problems.
Best regards,
