[Gdal-dev] Re: [Proj] Dataset mismatch?
Michael P Finn
mfinn at usgs.gov
Fri Jan 27 12:52:09 EST 2006
>From my colleague Lynn Usery (USGS/ Geospatial Information Office). Mike
Finn
Using 2 points is not sufficient. The user should use a grid of at least
20 x 20 points (400 total points) over the quad. Transform those between
the datums and resample the pixels based on this approach. This is a
simple operation in Imagine which automatically locates the control
points then applies the datum tranformation, interpolates and resamples
the data. Of course Jarrett said no commercial software, so he must find
a way to implement this process with open source code.
To perform the datum transformation, two points is just not enough to
handle the differences between the two datums. NGS used thousands of
points in the transformation to determine the NADCON shifts between NAD
27 and NAD 83 for the US.
Lynn
"Jarrett L. Redd" <jarrett_l_redd at yahoo.com>
Sent by: proj-bounces at lists.maptools.org
01/27/2006 02:59 AM
Please respond to
"PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
To
gdal-dev at lists.maptools.org, proj at lists.maptools.org,
geotiff at lists.maptools.org
cc
Subject
Howdy...
Please forgive the long cross-posting. I'm new to this and don't know
exactly
who will have a possible answer for this issue of mine.
I'm a volunteer working on a avalanche terrain and runout mapping project
for
potential use by our mountain search and rescue teams. I'm using DRG 24k
topographical geotiff slices in UTM NAD27 and then processing 1/3 arc-sec
elevation .adf files in lat/lon NAD83 to match up and plot slopes and
such.
All this is downloaded from the NED seamless website.
Problem is, the two data sets don't match up precisely. That is, the
features
on the topo seem to match up precisely with elevation data in some places
and
not so precisely in others. At the worst, the error is around 500 feet.
I'm
using "libproj" to convert coordinates between the two datums. I'm
currently
processing a section of Colorado, and I'm building "libproj" to include
the
"conus" correction file. I've also verified my coordinate conversions are
correct by comparing against openEV and topoUSA. I'm also using "libgdal"
to
pull out the elevation data and "libgeotiff" to grab the image raster data
and
geo tags.
However, like I said, I'm new to this. I'm converting the NW and SE
corners of
the geotiff into NAD83 and then interpolating for each pixel to match up
with
the elevation data using the origin and resolution of the various
elevation
pieces. I have a sneaky feeling that life isn't that simple. Am I
missing
some fancy projection to correct for curvature of the earth or something?
Or
is this just an inherent mismatch between the data sets? Or both? Other
suggestions to try?
Please don't suggest using a commercially available mapping package since
we
have no money and I need to do very extensive data processing once I have
the
data sets matching up properly.
Thanks.
-Jarrett
P.S. Here's an example of a nearly 500 foot mismatch error:
A tiny rock spire on the topo map:
13 0394704 4334970
And the corresponding spike in elevation data:
13 0394571 4335039
[Coords provided by OpenEV cursor]
I don't expect a perfect matchup, but the worst areas need to be corrected
somehow to make the avalanche terrain maps useful.
I can email an example image showing the error if someone is really
interested.
Thanks again.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060127/72edb875/attachment.html
