[Gdal-dev] updates of deflate compressed tiff still broken?
Vincent Schut
schut at sarvision.nl
Mon Jan 30 09:27:26 EST 2006
Frank Warmerdam wrote:
>On 1/30/06, Vincent Schut <schut at sarvision.nl> wrote:
>>Frank et al.,
>>I'm trying to generate overviews for a compressed (deflate) tiff, which
>>doesn't work. I remember updating compressed tiff files being broken,
>>either in gdal or in libtiff or both, but has this since never been fixed?
>Vincent,
>I'm not too sure what is going wrong still with this. I was able
>to reproduce the problems with an averaged overview build on my
>test file (http://home.gdal.org/~warmerda/world.tif - converted to
>deflate) but without averaging it worked fine.
>Also, I found that addtiffo works fine with averaging, so
>till this is properly fixed, you might want to just use that.
>eg.
>addtiffo -r average abc.tif 2 4 8 ...
>The code should be very similar between gdaladdo and addtiffo
>but apparently there are significant differences.
>In the past my assumption has been that these problems related
>to issues in the "statefulness" of some of the libtiff codecs, but
>I'm not too sure of that anymore.
>You can file a bug on this if you wish, but I'm not sure when I'll
>get around to digging in deeply.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
Frank,
thanks for the info. I'll try with addtiffo. I already tried with the
ossim app img2rr but that is very slow... I liked the speed of gdaladdo.
Vincent.
