[Gdal-dev] NOAA 14 geocoding?
Charles Wivell
charles.wivell at dnr.state.mn.us
Mon Jan 30 10:38:27 EST 2006
Are the NOAA 14 images raw images? (still in sensor space?).
The AVHRR sensor has a very wide foot print (scan angles of +/- 55 degrees). This sensor requires a full satellite/sensor/earth/DEM model to accurately correct the images to map space. The AVHRR pixels bloom from 1.1 km to over 6 km (at end of scan) and there is a lot of parallax at end of scan, so a simple warp will not work well. While at EROS Data Center I wrote the model used to process AVHRR images.
I'd recommend acquiring an already geocoded image.
Chuck Wivell
MN DNR, Grand Rapids, MN
>>> Markus Neteler <neteler at itc.it> 01/30/06 7:01 AM >>>
I have ordered a coulpe of AVHRR images from CLASS archives
(http://www.class.noaa.gov) for Northern Italy:
ftp://ftp.class.noaa.gov/A2585871/
(each image 3-4MB).
To geocode them, I used gdalwarp but the images didn't
cover Northern Italy after geocoding (they appear East of
the Caspian Sea):
# apply GCPs with thin plate spline transformer
gdalwarp -tps -of HFA -t_srs "EPSG:4326" -co COMPRESS=YES \
NSS.LHRR.NJ.D99174.S1236.E1248.B2308484.GC.L1261491 \
NSS.LHRR.NJ.D99174.S1236.E1248.B2308484.GC.L1261491.img
The resulting images are also almost North-South oriented which
is unlikely.
I used the "generate map" feature of CLASS to verify the
position before ordering.
Is it possible that the NOAA 14 format differs?
Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
