[Gdal-dev] Wrong geometry type detected
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 30 14:12:17 EST 2006
On 1/30/06, Petteri Packalen <packalen at cs.joensuu.fi> wrote:
> Frank et al.
> I observed that the OGR recognizes incorrect point type in some occasions.
> When the real point type is wkbPoint25D but the Z-value is exactly zero
> getGeometryType() returns wkbPoint. This happens at least when the
> shapefile driver is used (GDAL 1.2.6.0).
> I cannot see this to be preferred logic, or do I miss something?
Petteri,
There was a major overhaul of OGR geometry in the
early fall of 2005 to carry along coordinate dimension
information explicitly. That overhaul should fix the particular
problem you are seeing.
I would encourage you to upgrad eto GDAL 1.3.1.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
