[Gdal-dev] KML support
Matthew Perry
perrygeo at gmail.com
Tue Jan 31 12:10:38 EST 2006
Joern,
If you need to get KML into an ogr compatible format, I came up with
a method to convert kml to a shapefile. It's just a simple shell
script that converts kml -> gml (using Christian Spanring's xslt) then
gml -> shp (using ogr2ogr).
http://www.perrygeo.net/wordpress/?p=3
Matt Perry
On 1/31/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On 1/31/06, Jørn Vegard Røsnes <jorn at spacetec.no> wrote:
> > Hi,
> > are there plans to implement KML/Google Earth support in ogr2ogr.
> > KML files can have points, linestrings and polygons.
> > http://www.keyhole.com/kml/kml_tut.html
> Joern,
> I have no plans to implement KML support.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Matt Perry
