[Gdal-dev] Is there a GetRasterBandasRGB?
Wed Jul 5 10:08:43 EDT 2006
Christopher Barker wrote:
> Hi all,
> I've been starting to work with GDAL (mostly with the python bindings),
> and I've been very impressed, it's a very nice piece of work. I'm
> particularly thrilled with the BSB support.
> What I need to do is be able to read any (ideally) form of
> geo-referenced raster image that GDAL supports, and then get a 24 bit
> RGB version of a given subset of the image.
> I've found I can use GetRasterBand() to extract the data I want.
> However, I found myself having to write different versions of the code,
> depending on how the data was stored:
> if is is a single band raster, with a ColorTable, I do one thing
> If it's a three band raster, with RBG bands, I do another
> etc.....
> Those are the two I've supported so far, but then it downed on me that
> my needs can not be unique! this must be a pretty common problem.
> So the question is, have I missed a function that extracts a subsection
> of the rasterdata, and converts it to RGB data for me? If it's not built
> in to GDAL, has anyone written such a thing, and/or would this be the
> kind of thing that you'd like to add, if I write it?
Chris,
I'm afraid you have not missed a function.  You basically need to do this
yourself.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
