[Gdal-dev] Re: ruby bindings not compiling from CVS
Ken-ichi Ueda kueda at nature.berkeley.edu
Wed Jul 5 18:43:18 EDT 2006
Hi Charlie et al.,
I just gave this another shot, this time on Ubuntu 6.06, and got exactly
the same error:
(cd man; make install)
make[1]: Entering directory `/usr/local/src/gdal-cvs-2006.07.05/man'
/usr/local/src/gdal-cvs-2006.07.05/install-sh -d /usr/local/man/man1
for f in man1/gdaladdo.1 man1/gdal-config.1 man1/gdal_contour.1
man1/gdalinfo.1 man1/gdal_merge.1 man1/gdal_rasterize.1
man1/gdaltindex.1 man1/gdal_translate.1 man1/gdal_utilities.1
man1/gdalwarp.1 man1/ogr2ogr.1 man1/ogrinfo.1 man1/ogrtindex.1
man1/ogr_utilities.1 man1/pct2rgb.1 man1/rgb2pct.1 ; do
/usr/local/src/gdal-cvs-2006.07.05/install-sh -c -m 0644 $f
/usr/local/man/man1 ; done
make[1]: Leaving directory `/usr/local/src/gdal-cvs-2006.07.05/man'
(cd swig; make install)
make[1]: Entering directory `/usr/local/src/gdal-cvs-2006.07.05/swig'
for dir in ruby ; do (cd $dir; make install ); done
make[2]: Entering directory `/usr/local/src/gdal-cvs-2006.07.05/swig/ruby'
make -f RubyMakefile.mk install
make[3]: Entering directory `/usr/local/src/gdal-cvs-2006.07.05/swig/ruby'
/bin/sh /usr/local/src/gdal-cvs-2006.07.05/libtool --mode=install
/usr/local/src/gdal-cvs-2006.07.05/install-sh -c gdal.so ogr.so
gdalconst.so osr.so /usr/local/lib/site_ruby/1.8/i486-linux/gdal
/usr/local/lib/site_ruby/1.8/i486-linux/gdal/gdal.so
install:  gdal.so does not exist
make[3]: *** [install] Error 1
make[3]: Leaving directory `/usr/local/src/gdal-cvs-2006.07.05/swig/ruby'
make[2]: *** [install] Error 2
make[2]: Leaving directory `/usr/local/src/gdal-cvs-2006.07.05/swig/ruby'
make[1]: *** [install] Error 2
make[1]: Leaving directory `/usr/local/src/gdal-cvs-2006.07.05/swig'
make: *** [install-actions] Error 2
Again, it looks like gdal.so just isn't getting built.  So either I'm
doing something dumb on OS X, Gentoo, and Ubuntu (a definite
possibility), or there's a deeper problem.  I would definitely
appreciate some help working through this, if you have the time.
-Ken-ichi
