[Gdal-dev] Using gdal_translate to translate from UInt32 to Byte
Thu Jul 6 12:20:43 EDT 2006
John Preston wrote:
> Band 1 Block=200x20 Type=UInt16, ColorInterp=Gray
> Band 2 Block=200x20 Type=UInt16, ColorInterp=Undefined
> Band 3 Block=200x20 Type=UInt16, ColorInterp=Undefined
> to a standard jpeg  or png that can be viewed with any image viewer.
> Each time I try gdal_translate -of JPEG xxx.tif xxx.jpg I get the
> following error:
> ERROR 6: JPEG driver doesn't support data type UInt16. Only eight bit
> byte bands supported.
> Is their any flag that I can use to read the UInt16 blocks and combine them
John,
The "-ot Byte" flag will tell gdal_translate to convert to byte.  You will
also likely want to scale the data or else everything above 255 will be
clipped to 255.  For default scaling use:
By the way, gdal_translate options are described online in the utilities
documentation:
   http://iweb.gdal.org/gdal_translate.html
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
