[Gdal-dev] the command tiffsplit.exe
Frank Warmerdam
warmerdam at pobox.com
Thu Jul 6 12:36:06 EDT 2006
Zhonghai Wang wrote:
> Hi Frank,
> I noticed that there is a command "tiffsplit.exe" in the folder
> \FWTools1.0.4\bin, I've played a little bit with this command, but I can
> not realize what this really is used for. Does this command do exactly
> the same things like the -co "TILED=YES" when performing the gdal commands?
> I have now about 200 tifs, and each is 8750*6000 pixels, so if the
> tiffsplit does the internal tile thing, it will be perfect for me.
Zhonghai,
TIFFs may contain multiple images in one file. Often each image is a page
in a fax or something similar. The tiffsplit program splits each image out
into a seperate file.
So, no, it won't help you in breaking images into smaller files, nor in
making them internally tiled.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
