[Gdal-dev] [Fwd: [Geotools-devel] Google Summer Of Code]
Mateusz Loskot mateusz at loskot.net
Fri Jul 7 17:09:12 EDT 2006
Simon Perkins wrote:
> Just wading in here late in the day and I missed the earlier part of
> this thread, but when you build GDAL on VS 2005, and use it in another
> project, you need to make sure you keep the gdal.dll.manifest file along
> with the gdal.dll library, in your path. Could that be the problem? For
> some obscure reason, when you build DLLs within the VS IDE, the manifest
> is embedded in the DLL, but when you build using nmake, it apepars as a
> separate file.
Yes, you're right.
Manifest can be embedded or generated as a separate file but it's required.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
