[Gdal-dev] "collect2: ld returned 1 exit status" building ogrinfo
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 12 18:16:42 EDT 2006
Maciej Sieczka wrote:
> Mateusz Loskot napisał(a):
>> Maciej,
>> As you can read in my post on the GEOS list, use --without-libtool when
>> building GDAL:
>> ./configure --without-libtool ...rest of your options.
>> This change is transparent for you, I mean you won't notice any
>> changes in GDAL behaviour or you won't need to take any further steps
>> to build it. Just pass it and build as usually: make, make install.
>> It should work. I tested it today with GDAL CVS and GEOS 2.2.3.
> Sorry I couldn't come back to you earlier.
> Thanks for "--without-libtool" tip. However, I have fetched GDAL CVS few
> minutes ago and tried if I really need that, still having GEOS 2.2.3
> installed. And, this time, no problems during make, in spite of not
> using "--without-libtool". GDAL built and installed just fine. Whatever
> the reason. Letting you know. Strange?
Maciek,
That's because Mateusz fixed GDAL!
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
