[Gdal-dev] Error while writing to .shp file.
Vidhiyadharan Nadarajah
vdharan2001 at gmail.com
Fri Jul 7 16:20:05 EDT 2006
Thanks for your suggestions. Now iam able to write to shapefile.
Best Regards,
N.Vidhiyadharan
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org]On Behalf Of Mateusz Loskot
Sent: Thursday, July 13, 2006 11:54 PM
To: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Error while writing to .shp file.
Vidhiyadharan Nadarajah wrote:
> Hi,
> I want to add a feature to an existing polygon layer. Iam getting errors
as
> follows.
> ERROR 3: Error in fseek() or fwrite() writing object to .shp file.
> ERROR 4: Failure writing .shp header.
The problem is that you're opening datasource in read-only mode.
> Please find below the code Iam using and indicate me what is wrong.
> *********** start********
> #include "stdafx.h"
> #include "ogrsf_frmts.h"
> int main()
> OGRRegisterAll();
> OGRDataSource *poDS;
> poDS =
RSFDriverRegistrar::Open( "C:\\Projects\\Test\\GDALTest\\shp\\india_ds.shp"
> , FALSE );
Note 1: There is no class called GRSFDriverRegistrar but
OGRSFDriverRegistrar.
Note 2: Change the second parameter from FALSE to TRUE.
> if( poDS == NULL )
> printf( "Open failed.\n%s" );
> exit( 1 );
> OGRLayer *poLayer;
> poLayer = poDS->GetLayerByName( "india_ds" );
> poLayer->ResetReading();
> if (NULL == poLayer)
> printf("Layer not found\n");
> OGRDataSource::DestroyDataSource(poDS);
> return -1;
> OGRFeature *poFeature = new OGRFeature( poLayer->GetLayerDefn() );
> // set the field
> poFeature->SetField( "State", "123" );
> OGRPoint *poPoint = new OGRPoint();
Remember to destroy the OGRPoint object pointed by poPoint
to avoid memory leak.
The member function
void OGRLineString::setPoint( int iPoint, OGRPoint * poPoint )
does not transfer ownership to point passed in.
Honestly, for better understanding this prototype should look as:
void OGRLineString::setPoint( int iPoint, const OGRPoint * poPoint )
because the poPoint is read-only inside the setPoint() function.
> OGRLinearRing *poLinearRing = new OGRLinearRing() ;
> poLinearRing->setNumPoints(4);
> poPoint->setX( 13 );
> poPoint->setY( 64 );
> poLinearRing->setPoint(0,poPoint);
> poPoint->setY( 66 );
> poLinearRing->setPoint(1,poPoint);
> poPoint->setX( 15 );
> poLinearRing->setPoint(2,poPoint);
> poLinearRing->setPoint(3,poPoint);
So, here is the deallocation:
delete poPoint;
> poLinearRing->closeRings();
> OGRPolygon *poOGRPolygon = new OGRPolygon();
> poOGRPolygon->addRingDirectly(poLinearRing);
> if(poFeature->SetGeometryDirectly( poOGRPolygon ) != OGRERR_NONE )
> printf( "Failed to Set Geometry.\n" );
> exit( 1 );
> if( poLayer->CreateFeature( poFeature ) != OGRERR_NONE )
> printf( "Failed to create feature in shapefile.\n" );
> exit( 1 );
> delete poFeature;
> OGRDataSource::DestroyDataSource( poDS );
> return 0;
Best regards
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.10/385 - Release Date: 11/07/2006
No virus found in this outgoing message.
