[Gdal-dev] AAIGrid driver reading Floating points incorrectly?
Mateusz Loskot mateusz at loskot.net
Fri Jul 14 11:22:11 EDT 2006
Christopher Condit wrote:
> Hi Bryan-
> I think that GDAL uses a shortcut to decide on the AAIGrid data type.
> Namely: scanning the first 100 bytes only and looking for any decimal
> places.  In your case it appears that the first line in all NODATA
> (integers).  I think if you change the first one of those to -99999.0
> you should see a change in how the driver handles the file.
Christopher,
After Bug 1071
(http://bugzilla.remotesensing.org/show_bug.cgi?id=1071)
has been fixed, the AAIGrid driver scans the whole file
to search for floatpoint values.
So, now it should be no difference if the float-point value is in the
first 100 bytes or after this junk.
Bryan,
What version of GDAL are you using?
Have you tested with latest 1.3.2 or CVS?
Best regards
Mateusz Loskot
http://mateusz.loskot.net
