[Gdal-dev] swig - gdal msvcr80.dll errors
Mateusz Loskot mateusz at loskot.net
Tue Jul 18 10:19:38 EDT 2006
Norman Barker wrote:
> Hi,
> I have built gdal using the Microsoft .Net SDK, and this works fine, all
> the binaries -  gdalinfo, gdal_translate,  everything works ok.
> I then proceeded to build the swig java libraries (I have done this on
> linux - works fine, just need to test on windows), these also build
> fine.  However when I run
> java –Djava.library.path –cp .;gdal.jar;apps gdalinfo
> I get the exception msvcr80.dll not found – which is true it isn’t!  The
> assembly version in the manifest files doesn’t match any in
> C:\WINDOWS\WinSxS however it works fine with the main GDAL build.  Does
> anyone have any ideas on how to fix this?  If I could make it point to a
Have you read these posts?
http://lists.maptools.org/pipermail/gdal-dev/2005-December/007534.html
http://lists.maptools.org/pipermail/gdal-dev/2005-December/007535.html
and this one:
http://forums.microsoft.com/msdn/showpost.aspx?postid=15218&siteid=1
You should be able to find solution there.
Best regards
Mateusz Loskot
http://mateusz.loskot.net
